Z axis not auto adjusting during print
Jamiegreen97
(@jamiegreen97)
Hi all,
My Z height was set and working fine until yesterday.. now during a print on the first layer the Z axis height says at 1.00mm across the entire bed and no auto adjustments are made, therefore Z high is incorrect in some areas of the bed.
Some observations:
1. Auto bed leveling is running before a print as normal (PINDA Sensor light goes on/off as it should)
2. PINDA Sensor stays off during print once started (which I think its supposed to be on right?)
3. Z height stays at nominal value across entire bed (ie. 1.00mm), not adjusting by 0.05mm as to moves etc.
Any ideas would be very apricated.
Thanks, Jamie
Publié : 27/02/2023 3:16 pm
Jamiegreen97
(@jamiegreen97)
RE: Z axis not auto adjusting during print
Update - The indicated Z height is staying at 1.0 even if I leave the print running for a few layers. But on bed leveling before a print and moving the axis before a print, it registers the Z axis changing
Publié : 27/02/2023 6:33 pm
