[Resuelto] Z-axis jammed on most of its range of motion
JustAnotherAve
(@justanotherave)
Hi everyone.
I've had my Mini+ for around a month now, and it has been working well. I recently had to re-mount my x-axis to the z-carriage, but after re-mounting, the carriage has had trouble moving. When instructed to move, the z-motor will make a grinding/vibrating noise and move very little. The axis moves freely on some small ranges (usually 1-2mm). I've tried mounting the x-axis again and checking the bearings, but neither fixed the issue. I've also checked to see if the z-screw is grinding its mount, but that doesn't seem to be the case either.
I'm stumped here, any help is greatly appreciated!
Best Answer by Chris Laudermilk:
Sounds like the trapezoidal nut is over tightened. Can you freely rotate the Z lead screw with the printer off?
Respondido : 04/04/2022 4:57 pm
Chris Laudermilk
(@chris-laudermilk)
RE: Z-axis jammed on most of its range of motion
Mini+ (kit) - Revo Micro | Antler Cooling | WiFi (4.4.0RC1)
Respondido : 05/04/2022 1:55 pm
JustAnotherAve
(@justanotherave)
Hey, thanks a ton! Loosening the trapezoidal nut screws by about half a rotation each fixed it. Ironically, I was worried that the trapezoidal nut might be too loose. Really appreciate the help!
Respondido : 05/04/2022 4:13 pm
Chris Laudermilk
(@chris-laudermilk)
Glad that worked. That part is counter-intuitive; they need to be just barely tight enough to keep the X axis from rattling, but no more.
Respondido : 06/04/2022 3:58 pm
