Z Axis fail ... nozzel pushed down front right side, it has worked for a while
Mtnplaya
(@mtnplaya)
My last print failed and now the z axis is messed up, I tried to recalibrate and i did a live X axis adjsut but every time I try the test it hits the bed, pushes it down and just buzzes. I would appreciate any help.IMG_0233 2
Posted : 22/07/2025 1:22 pm
_KaszpiR_
(@_kaszpir_)
Seems like your MINDA/PINDA sensor is not working.
See https://help.prusa3d.com/article/m-i-n-d-a-superpinda-sensor-testing-mini-mini_134021
Posted : 22/07/2025 8:22 pm
Kenyiro34
(@kenyiro34)
RE: Z Axis fail ... nozzel pushed down front right side, it has worked for a while
put donw your minda and check again
Posted : 07/10/2025 5:46 pm
Kenyiro34
(@kenyiro34)
i mean my own post you need move litte down your minda i use 1,4mm spacer. before i test i i use paper and put nozzle down to touch paper and calibrate minda , and this work.
Posted by: @kenyiro34
Posted : 08/10/2025 10:36 am
