X-Axis Home Wrong
I have a print that is using the max size of my build plate but I can't print it because the X-axis home is to far to the right, about 3mm. I checked and redid the Z-axis assembly but that didn't help. Is there a way to put in an offset for the X-axis?
I made a 3mm thick spacer to slide over the top X-axis rail and this adjusted the home temporarily.
KO
Opublikowany : 26/03/2021 11:41 pm
RE: X-Axis Home Wrong
4.3.1 or 4.3.2 beta
Stock MK4S with FW 6.2.6
Opublikowany : 27/03/2021 9:35 am
Topic starter
answered:
I have 4.3.1, which I recently upgraded to. A friend asked if I reran the calibration Wizard after I installed the upgrade, and I haven't. Will that make a difference?
I just started printing and has been working fine otherwise.
Opublikowany : 31/03/2021 2:59 am
