Viewing files on original USB key
mvinfo@virgilio.it
(@mvinfovirgilio-it)
Hello and thanks in advance, if anyone will be able to help me solve this "problem".When I save the .gcode files on the USB key connected to the pc (WIN10) and then insert it in the Prusa Mini +, here I see them in order of insertion and not in alphabetical order as they appear when the key is connected to the pc. Since there are many files, it is very inconvenient for me to search for the file, which I need to print at that moment, without having an alphabetical order. Can anyone tell me if there is a solution to change the display type of the files on the USB key when it is connected to the Prusa MINI +.
Thank you
Veröffentlicht : 27/12/2021 2:17 pm
MysDawg
(@mysdawg)
RE: Viewing files on original USB key
I use OctoPrint, so all the files are in alpha order. That being said I have folders set up on my key for backup storage. You can go into windows and pull up the key as a USB drive to view the files. I have folders set by filament type and then by category. That way if I have a particular filament that I'm printing with at the moment I can print files from that folder.
Veröffentlicht : 27/12/2021 6:39 pm
mvinfo@virgilio.it
Thank you very much for your reply!
Veröffentlicht : 03/01/2022 1:27 pm
