Uneven temperatures across heatbed
Alabuk
(@alabuk)
Miembro
First off, I bought my printer used, so I don't know all of it's history.
I downloaded one of the Z-offset calibration patterns from Printables.  I am printing with PETG on a satin sheet.  I had a lot of trouble with the PETG not sticking in front third of the heatbed.  I used a laser thermometer to measure the temperature at various points on the heatbed, and the front third of the hotbed is 10-15C cooler than the rest of the bed.  Any idea why this might be happening?  Or is it just time to replace the heatbed?
Este debate ha sido modificado el hace 2 years por Alabuk
Respondido : 30/08/2024 10:07 pm
_KaszpiR_
(@_kaszpir_)
RE: Uneven temperatures across heatbed
can you provide temperatures with the bed sheet on it?
Either way maybe bed quality wasn't the best so maybe it's worth to replace.
Respondido : 31/08/2024 7:29 am
Variation like that can be caused by as litle as a light draft...
but we can't really judge the first layer until you get the print sheet properly clean - look up threads here about cleaning.
Then protect from drafts, allow time for the print sheet temperature to stabilise and try again.
Come back if problems persist.
Respondido : 31/08/2024 10:45 am
Alabuk
(@alabuk)
Miembro
Here’s more of the steps I’ve taken debugging this issue:
I have cleaned my sheet with dish soap and water, followed by 99% IPA with no improvement
I’ve dedicated one side of this sheet to PETG and the other to PLA.   I get similar results with PLA on the PLA side of the sheet.
I print in an acrylic enclosure, and I get the same issue with the door open and closed.
Respondido : 03/09/2024 12:38 am
_KaszpiR_
(@_kaszpir_)
Replace the bed or learn to limit used area when printing.
Respondido : 03/09/2024 6:11 am
Your pictures clearly show poor adhesion even where the first layer looks OK  - if regular cleaning isn't working then maybe it's time for a drastic clean...
Work neat dishwashing detergent (Dawn/Fairy) into the surface of the sheet - wait for ten minutes then rinse it away with very *HOT* water.  Dry by dabbing with a fresh paper towel, handle by the edges only and finish drying by placing it on the heatbed and raising the temperature.
Adjust your first layer Z offset so the centre of the pattern is best and show us the result.
Respondido : 03/09/2024 6:45 am
