Under extrusion? at start of seam
Matt
 Matt
(@matt-28)
I recently tried printing some PLA fidget stars with my Prusa Mini+. Several years ago I had no issues when printing the design. Recent efforts show what appears like under extrusion at the start of each seam (see pictures below). I contacted Prusa support and have already ruled out issues with:
-The type, age and condition of the filament
-The hotend PFTE tube (I have replaced this with no improvement)
-Extruder spring tension
-Cleanliness of the extruder mechanism (now clean)
-Cleanliness of the hotend (no blockage)
- Firmware and Prusaslicer fully updated
As suggested by Prusa, I tried tweaking the de-retraction setting. This helped at the seam, but then pushed out so much filament that prints were colliding with the nozzle. Prints were knocked off every time.
The machine has only seen hobby use. The problem continues. Do any Mini+ users have a potential solution?
Opublikowany : 04/01/2026 8:40 pm
_KaszpiR_
(@_kaszpir_)
RE: Under extrusion? at start of seam
Check the ptfe tube between the extruder and the hotend ( the long one).
Can you provide more details about the model orientation on the bed, where the seam is located? Or maybe you could share 3mf file as zip?
Opublikowany : 05/01/2026 8:03 am
Matt
 Matt
(@matt-28)
Hello,
Thank you for interest in my printing problem. This is causing me quite a bother. I am normally quite good at solving issues like this. In this case, I need expert advice.
I have checked the PTFE tube between the extruder and hotend. I do not see any physical damage or wear. Could I be looking for something else here?
The star is positioned flat on the bed and the seam joint is positioned towards the upright support column of the Prusa Mini (RHS when viewed from the front)
Here is the zipped 3mf file as requested.
fidget_star_8_8
Kind regards
Matthew
Opublikowany : 05/01/2026 8:39 pm
_KaszpiR_
(@_kaszpir_)
Try switching to Prusament PLA @MINIIS, I glanced at the ESUN  filament profile and it has some custom gcode on start that changes PA setting, and this may cause issues.
Do you get those uneven extrusions in other parts of the print? (other seams in internal star elements)
Opublikowany : 06/01/2026 1:22 pm
Matt
 Matt
(@matt-28)
Hello,
I will certainly try changing the filament profile to Prusament PLA as suggested. Will test at the weekend. The uneven extrusions do seem to appear on the inner star elements. Thanks for your ideas.
Matthew
Opublikowany : 07/01/2026 9:29 pm
Matt
 Matt
(@matt-28)
I have tried the Prusament profile... no luck- the issue persists. Do have any further thoughts?
Opublikowany : 11/01/2026 8:48 pm
_KaszpiR_
(@_kaszpir_)
Input Shaping tuning or retraction tuning would be next tests
Opublikowany : 12/01/2026 8:58 am
Matt
 Matt
(@matt-28)
I already had a go at making minor adjustments to the detraction setting. Increasing his helped to improve the cosmetics. I did this in small incremental steps just until the flaws disappeared. The problem is that this resulted in excess filament being deposited on the other side of the print and the nozzle knocked it off each time. Adjusting the setting almost seems like applying Band Aid bandage, rather than resolving the cause- could the problem be a blockage? - I can't see one.
The problem even occurs without Input Shaping.
Opublikowany : 14/01/2026 9:14 pm
_KaszpiR_
(@_kaszpir_)
If you suspect blockage then try cold pulls or try with another clean nozzle?
Opublikowany : 15/01/2026 8:08 pm
Matt
 Matt
(@matt-28)
Thank you for all the advice. I will certainly try another cold pull.
At this stage I am thinking of taking a small gamble and replacing wear components related to the filament: Nozzle and all PTFE tubing after the extruder. I would probably avoid replacing the extruder itself. Can you think of any other 'consumable' items?
Opublikowany : 18/01/2026 9:00 pm
