Ultimaker Cura profile for Prusa MINI
Gianki
(@gianki)
Hi everyone, I would like to use the Ultimaker Cura software with my Prusa MINI, but when I use it, there is no profile for the Prusa MINI, only the models are supported: i3, i3 Mk2, i3 Mk3 / Mk3s and i3 xl .
Can anyone tell me how I can set Cura for the Prusa MINI?
Thank you.
Publié : 15/10/2020 12:10 pm
Robeena Shepherd
(@robeena-shepherd)
RE: Ultimaker Cura profile for Prusa MINI
You can download them here: https://help.prusa3d.com/en/guide/how-to-import-profiles-to-cura-4-x-windows-macos_17848#17856
Publié : 18/10/2020 11:12 pm
2 personnes ont aimé
Gianki
(@gianki)
RISPONDI: Ultimaker Cura profile for Prusa MINI
@robee
I did, but when I then go to print, the print goes out of bed and it also goes wrong.
Publié : 19/10/2020 9:14 am
alan
 alan
(@alan-2)
upgraded to cura 4.9
cannot add prusa mini  followed instructions
when you add the new printer cura crashes  or atleast it dos for me
work on 4.8
thanks
Publié : 24/04/2021 12:20 pm
Cipis
(@cipis)
Membre
I just tested it with Cura 4.9.0 (Windows). I have no issues with profiles from https://help.prusa3d.com/en/guide/how-to-import-profiles-to-cura-4-x-windows-macos_17848#17856. It is likely some issue with your Cura installation.
Publié : 24/04/2021 3:49 pm
alan
 alan
(@alan-2)
ok thanks
i must have messed up
thanks
Publié : 24/04/2021 5:02 pm
alan
 alan
(@alan-2)
thanks
sorted unistall cura and reinstalled
mini just appeared
thanks
Publié : 24/04/2021 5:31 pm
Chris Barnes
(@chris-barnes)
I reviewed this thread and I still have a problem.  My scenario goes like this - Running Ubuntu 20.04 LTS.  Tried using the normal .AppImage file and followed the instructions from https://help.prusa3d.com/en/guide/how-to-import-profiles-to-cura-4-x-windows-macos_17848#17856.&_ga=2.115276800.627010643.1630169805-2071169588.1630007503 and there are no other .json in the directories so that seemed odd.  So I completed all of the steps and even rebooted my machine during the process and I still do not see the Prusa MINI.
Next I thought I would try using the SNAP method but in snap, the .json files are located in a read only directory.  This directory is set as read only by snap and attempting to modify or paste the files proved unproductive.
Can anyone assist with this?
-Chris
Publié : 28/08/2021 6:14 pm
Chris Barnes
(@chris-barnes)
I kept meaning to post this for those looking here to resolve this.
I have tested Ultimaker Cura 5.2.1 importing the Original Prusa Mini+ resources.  The "How To" guide provides all of the relevant information.  The new folder path for Cura 5.2.1 should be "C:\Program Files\Ultimaker Cura 5.2.1\share\cura\resources " for Windows10.
Publié : 19/11/2022 9:46 pm
1 personnes ont aimé
Wojciech
(@wojciech-2)
SOLVED!
Thank you.
Publié : 10/01/2023 8:10 pm
Tinu76
(@tinu76)
Membre
Still working with Cura 5.10.0 on Windows 11.
Path is "C:\Program Files\UltiMaker Cura 5.x.x\share\cura\resources" as noted by @chris-barnes.
Cheers, Martin
Publié : 29/03/2025 8:23 pm
seb-835
(@seb-835)
Still working in 2025-12-24 with Cura 5.11.0 on Linux
Path is "~/.local/share/cura/5.11/"
you might have to create "~/.local/share/cura/5.11/meshes/" folder to copy the plater stl file as it does not exist.
refs:
https://community.ultimaker.com/topic/19565-how-to-migrate-resource-files-from-windows-to-linux-cura/
Kind regards and happy holiday season to everyone
Publié : 24/12/2025 4:50 pm
Ben levelmyb3d
(@ben-levelmyb3d)
Membre
Still working in Cura 5.12.0 on Mac.
I've attached the folder structure for any users interested. Just merge these folders / files with what already exists in:
/Users/[name]/Library/Application Support/cura/5.XX.X
...then in the Cura app, go to:
Add Printer > Non-Ulitmaker Printer > Add a non-networked printer (accordion tab) > Prusa Research > Original Prusa MINI
and follow the instructions to set up.
If the zip file isn't available to download, here's the folder structure:
Profile files ZIP:
MINI_cura_profiles for 5.12.0
Publié : 06/04/2026 10:54 am
