Ultimaker Cura profile for Prusa MINI
Hi everyone, I would like to use the Ultimaker Cura software with my Prusa MINI, but when I use it, there is no profile for the Prusa MINI, only the models are supported: i3, i3 Mk2, i3 Mk3 / Mk3s and i3 xl .
Can anyone tell me how I can set Cura for the Prusa MINI?
Thank you.
RE: Ultimaker Cura profile for Prusa MINI
You can download them here: https://help.prusa3d.com/en/guide/how-to-import-profiles-to-cura-4-x-windows-macos_17848#17856
RISPONDI: Ultimaker Cura profile for Prusa MINI
@robee
I did, but when I then go to print, the print goes out of bed and it also goes wrong.
upgraded to cura 4.9
cannot add prusa mini followed instructions
when you add the new printer cura crashes or atleast it dos for me
work on 4.8
thanks
I just tested it with Cura 4.9.0 (Windows). I have no issues with profiles from https://help.prusa3d.com/en/guide/how-to-import-profiles-to-cura-4-x-windows-macos_17848#17856. It is likely some issue with your Cura installation.
ok thanks
i must have messed up
thanks
thanks
sorted unistall cura and reinstalled
mini just appeared
thanks
I reviewed this thread and I still have a problem. My scenario goes like this - Running Ubuntu 20.04 LTS. Tried using the normal .AppImage file and followed the instructions from https://help.prusa3d.com/en/guide/how-to-import-profiles-to-cura-4-x-windows-macos_17848#17856.&_ga=2.115276800.627010643.1630169805-2071169588.1630007503 and there are no other .json in the directories so that seemed odd. So I completed all of the steps and even rebooted my machine during the process and I still do not see the Prusa MINI.
Next I thought I would try using the SNAP method but in snap, the .json files are located in a read only directory. This directory is set as read only by snap and attempting to modify or paste the files proved unproductive.
Can anyone assist with this?
-Chris
I kept meaning to post this for those looking here to resolve this.
I have tested Ultimaker Cura 5.2.1 importing the Original Prusa Mini+ resources. The "How To" guide provides all of the relevant information. The new folder path for Cura 5.2.1 should be "C:\Program Files\Ultimaker Cura 5.2.1\share\cura\resources " for Windows10.
SOLVED!
Thank you.
Still working with Cura 5.10.0 on Windows 11.
Path is "C:\Program Files\UltiMaker Cura 5.x.x\share\cura\resources" as noted by @chris-barnes.
Cheers, Martin
Still working in 2025-12-24 with Cura 5.11.0 on Linux
Path is "~/.local/share/cura/5.11/"
you might have to create "~/.local/share/cura/5.11/meshes/" folder to copy the plater stl file as it does not exist.
Kind regards and happy holiday season to everyone
Still working in Cura 5.12.0 on Mac.
I've attached the folder structure for any users interested. Just merge these folders / files with what already exists in:
/Users/[name]/Library/Application Support/cura/5.XX.X
...then in the Cura app, go to:
Add Printer > Non-Ulitmaker Printer > Add a non-networked printer (accordion tab) > Prusa Research > Original Prusa MINI
and follow the instructions to set up.
If the zip file isn't available to download, here's the folder structure:
Profile files ZIP:
MINI_cura_profiles for 5.12.0
