Temperature on LCD doesn't match PrusaSlicer setting
Tracy
(@tracy)
In PrusaSlicer, I always select Prusa PLA for the filament. The default extruder temps are 215 (first layer) and 210 (other layers). I never change these. I've noticed that during all of my prints, the temperature reading on the LCD says 215 during the entire print. Is this normal?
Opublikowany : 28/02/2020 8:55 pm
Clemens M.
(@clemens-m)
RE: Temperature on LCD doesn't match PrusaSlicer setting
That's not normal - at my both Prusa printers using Slicer it is as it should. Check your settings in Slicer - that works for more than 3 years without any problem on my prints.
Best regards, Clemens
Opublikowany : 28/02/2020 9:07 pm
