SuperPINDA fail that isn't
Kapazitaet
(@kapazitaet)
Hi!
I just want to inform you about an issue I had with my Prusa Mini. When printing the printer would shut down presenting me with a QR code error message "Homing Error". After following the instructions linked via the QR code
https://help.prusa3d.com/article/homing-error-12301-mini_382501
and exchanging the Super PINDA and basically disassembling and reassembling the whole printer I found, that the issue is basically a firmware one.
Every Firmware above 4.3.4 will present with that error on my machine. After going back to 4.3.4 I had no issues of that kind anymore.
If you have the same problem, here is my instruction: Go to the software download
https://help.prusa3d.com/downloads/mini-2/firmware
Download the file, unzip it and put it on a USB drive. Insert the drive into your machine.
Restart the printer. Press the reset button next to the dial. Wait, until the reset process started and press the dial button once. The firmware flashing process starts.
Happy printing.
Napsal : 29/07/2023 11:17 am
