Something is not alligned
huleboer
(@huleboer)
So I've noticed there's quite a big difference between the placement of the print in prusa slicer vs the print bed.
Can anyone tell me how to correct this?
It will become an issue if I need to print something large that comes close to the edges of the bed.
Posted : 20/01/2022 3:44 pm
RE: Something is not alligned
Are you using the correct printer profile?
If you use a Mk3 profile for a mini, the print will be offset to the right and rear of the build plate.
because the mini has a smaller build plate area.
Posted : 20/01/2022 5:09 pm
fuchsr liked
Zoltan
(@zoltan)
Member Moderator
When yo take a look at the x axis, your sheet is shifted a bit to the left side (2mm?)
Regarding the y axis this could be a issue of the axis calibration and homing.
Does your xyz tests work fine?
Plug in the USB stick and run xyz axes test. The outpur of this test is a test___blabla...._xyz.txt file. Inside of the file you will see what yxyz axes length the test discovered.
After the test is finished see your settings->move axes there should be x=176, y=24
move y to y=0 and you will see, where the nozzle tip will point. If it is too far from the lines edge, thre is something wrong.
Posted : 20/01/2022 5:27 pm
Loewekordel
(@loewekordel)
Seems to be a more or less common issue:
https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/my-mini-isnt-printing-on-same-location-as-prusaslicer-is-showing/#post-508768
https://forum.prusa3d.com/forum/assembly-and-first-prints-troubleshooting/heatbed-not-centered/#post-503305
Watch out to not hit one of the print bed alignment screws with the nozzle with this offset!
Posted : 23/01/2022 5:48 pm
