Slight underextrusion on the Mini+
WormyMaple
(@wormymaple)
Mitglied
Hey there, I've been struggling with a slight underextrusion issue on my Mini+, and have not been able to fix it. It seems to essentially exclusively happen on corners and seams (as seen in the image below), which leaves thin parts quite frail and generally detracts from the look of a part. I've serviced the extruder and hotend several times now, but this has only lead to minor improvements. I'm running the latest firmware as well as the latest version/profiles of PrusaSlicer. This happens at any print speed, using any stock profile (w/ input shaping and w/o), and with any filament.
My only thoughts are that it could be a failing extruder stepper, or that my nozzle which has ~500 print hours on it (though no serious visual issues) is somehow causing the problem.
Any ideas for alleviating this issue would be appreciated.
Spoked printed model, showing underextrusion at corners
Veröffentlicht : 20/11/2024 4:18 pm
