Short curcuit after cleaning heaterblock
dnkcz
(@dnkcz)
Hi, I was cleaning heaterblock, because it was all clogged. I had printer ON so that i can take PLA of the heater block more easily. But then - probably from part - there was spark and printer turned off. Do you have any ideas how to troubleshoot that or repair? I try to plug heater part of the board, but it wont turn on. Fcuk  😢
Postato : 17/06/2024 3:03 pm
RE: Short curcuit after cleaning heaterblock
Check all the fuses
Postato : 17/06/2024 9:47 pm
dnkcz
(@dnkcz)
They are looking smoked. but i see inside the pastic there is wire between them, but i try to replace them.
Postato : 18/06/2024 8:30 am
Woodburner
(@woodburner)
Did I just ruin everything? (sparks = bad)  Read this post from 4 months ago in Prusa Mini it might help you.
Master of Wood Disaster
Charter member of the woodturners funnel club
Postato : 02/07/2024 5:26 pm
dnkcz
(@dnkcz)
It worked by replacing fuses. thanks 🙂
Postato : 25/01/2025 11:13 am
mark
 mark
(@mark)
You should consider a silicone sock on the print head. They keep stuff from sticking. Levendig made the originals. I suggest buying from them to support the work they did on the design, now copied by others.
Regards,
Mark
Postato : 25/01/2025 11:26 pm
