Sending commands via console port
make717ryan
(@make717ryan)
I'm struggling to find a way to send control commands to our Minis, MK4s and XL over serial ports. I am monitoring the printer for activity via the micro USB/USB C ports, using 57600 baud and 8/N/1. I have no trouble reading and parsing the information coming through. What I haven't been able to get working is sending basic commands like M604 to cancel a print in progress if it's outside approved time limits (maker space) or an alert via M0 (M0/M1 still don't work as advertised - opening up a request on github separately for that).
Sending commands via Pronterface works fine, though I see the connection is at 115200/8/N/1.
Am I missing something here, like DTR, DCD, CTS flags? I have the same issues in Realterm, Tera Term, putty, any console software.
Any advice would be appreciated.
-Ryan
Publié : 31/01/2025 6:48 am
make717ryan
(@make717ryan)
RE: Sending commands via console port
Updating: I was able to interact at 115200 8/N/1.. Unfortunately I haven't been able to find a way to abort a print regardless of the current progress. Is this possible, or do I just solder to the reset pin? 😛
Publié : 16/02/2025 5:36 am
_KaszpiR_
(@_kaszpir_)
You can send abort command via web API (PrusaLink),.it may be much more convenient.
Moreover you could connect them to Home Assistant and control there.
Publié : 16/02/2025 11:20 am
make717ryan
(@make717ryan)
We aren't deploying Home Assistant at our maker space just to abort a print, thanks though. I specifically need to prevent or abort a print before it starts unless the user is authorized by a separate stand alone device. Was hoping to do it without having to maintain custom firmware, but that may be the only way at this point.
Publié : 18/02/2025 3:32 am
adys
 adys
(@adys)
I am using CoreOne with octoprint. I was able to cancel the job (which was waiting for me to confirm I am foolish enough to print a job sliced for PLA when I have PETG loaded) with just M604. I am using `Auto` baud rate, which it settled on 250000!
Publié : 12/11/2025 6:25 pm
