Seam issues
nsanti
(@nsanti)
Seam issues
I’ve been having problems with seams on my mini+. This print was done at 210C with PLA, fans at 100% except for the first layer. The printer is running the latest firmware and Prusaslicer is updated to the latest version. This print was done without the input shaping preset in the slicer. I tried Input shaping in the past and got a result like this as well. I have already tried a new nozzle and it didn’t help at all.
Napsal : 14/01/2024 11:41 pm
mark
 mark
(@mark)
RE: Seam issues
This is a known issue with the input shaper and has been discussed in other threads including this one:
https://forum.prusa3d.com/forum/input-shaper-mini/under-extrusion-or-gaps-at-seams-with-input-shaper-settings-and-5-x-firmware/#post-689277
Exactly what versions of the slicer and firmware are you using?
Regards,
Mark
Napsal : 15/01/2024 2:13 pm
nsanti
(@nsanti)
RE: Seam issues
Firmware is 5.1.2. Slicer is 3.7.1.
I’m not sure how input shaper is the cause since this print did not use the input shaper.
Napsal : 15/01/2024 5:44 pm
