Prusament PLA keeps streaking and curling off bed
Mike Jeffries
(@mike-jeffries)
Hi everyone!
i havent used my printer in a few months and then when i went to use it, i started getting streaks where the nozzle would lift off the bed to move to a different area but then some PLA will be left and its carrying over to a different area and then leaving little blotches.
i changed the nozzle now and now trying different prusament PLA, and its still happening
is this a problem of over extrusion, or bed adhesion? It happens on both first layer and even at higher levels too (although not as much).
what do i do?
i attached 2 pics. This is a minor example of it, but on the bottom right you can see it left a blotch.
Napsal : 20/02/2022 1:02 am
RE: Prusament PLA keeps streaking and curling off bed
Supports are difficult.  I suspect your Z offset of not perfect.
Napsal : 20/02/2022 1:24 am
Mike Jeffries
(@mike-jeffries)
Ye thats what i keep reading. Ill keep trying to calibrate it and see if i find a better z offset
Napsal : 20/02/2022 1:29 am
