Prusa Mini reset/reboot on heaters
Tom Hofman
(@tom-hofman)
First I thought it would be the defective thermistor issue but I've replaced both the thermistor and the heater cartridge and it's still resetting on any temperature setting.
Prusa Mini (2020)
No longer is able to heat up.
Factory Reset
Can't get past calibration with heaters because it automatically resets/reboots.
Fuses look good, all connections seem fine.
Any ideas?
Opublikowany : 04/05/2024 4:49 pm
RE: Prusa Mini reset/reboot on heaters
if you set the bed temperature to 0Centigrade does the printer start heating the extruder? there my be a short in the bed heating circuit
Opublikowany : 04/05/2024 9:03 pm
Tom Hofman
(@tom-hofman)
No any temperature higher than current temperature of the parts thermistor and it resets. Even with all hardware disconnected from the board. I've ordered a new board and power supply which was recommended by chat support. Fingers crossed there's a fix among those parts!
Opublikowany : 04/05/2024 9:25 pm
Good Luck Tom,
Opublikowany : 04/05/2024 9:40 pm
