Original Prusa MINI & MINI+ WIFI Troubleshooting.
[Épinglé] Original Prusa MINI & MINI+ WIFI Troubleshooting.
Page 7 / 8
Alen Mencej
(@alen-mencej)
Membre
RE: Original Prusa MINI & MINI+ WIFI Troubleshooting.
I have exactly the same problems.
Most of the time my Mini+ doesn't even connect, but when it does it's mostly not responding. Whenever it connects and I successfully upload a file it becomes unresponsive after printing, to a point that I have to turn off and on the printer again, each and every time.
Also, the printer is 50 cm away from the router so that's not a problem.
Publié : 03/11/2023 10:20 am
cwolt
(@cwolt)
Membre
Hi, i am having troubles getting the wifi running on my Prusa mini.
I ordered the AZ-Delivery ESP8266 ESP-01S, which i think should be comatible.
After installing everything, flashing works but it doesn't connect to wifi. The blue LED flashes a couple of times but nothing more.
I tried reseating the module. Flashing again and loading the wifi config.ini again. So far nothing works.
Firmware Version: 5.1.2+13478
Bootloader Version: 2.3.4
Buddy Board Version: 2020 rev 1.0.5
I also get this message. (I always clicked Yes)
Publié : 23/01/2024 2:57 pm
cwolt
(@cwolt)
Membre
Edit:
It seems to work, when i change my Router SSID config to SSID=prusa PSK=prusa1234567
Previously i had this configuration:
[wifi]
ssid = Redacted-Wireless
psk = #ABcdEFg1234!
Publié : 23/01/2024 3:18 pm
probably because of the - symbol in the Middle of the  SSID...
Publié : 23/01/2024 4:35 pm
TeachThePrints
(@teachtheprints)
Posted by: @joantabb
Would having spaces also cause issues? My SSID is = "Free Internet 4 All", but the Mini doesn't connect to it anymore. With the 5.1.2 FW, it gets stuck on the same page as cwolt.
Prusa Mini FW6.2.4
Publié : 23/01/2024 5:03 pm
Try it. And let usb know
Publié : 23/01/2024 9:13 pm
TeachThePrints
(@teachtheprints)
For whatever reason did updating to 5.1.2 and filling out the credentials from within PrusaSlicer solve the issue.
Prusa Mini FW6.2.4
Publié : 24/01/2024 7:17 am
cwolt
(@cwolt)
Membre
If that is the case, then they should maybe mention this in the guide since having "-" in the SSID is not unusual.
Guigs
(@guigs)
Hi, I'm having issues setting up wifi on my Prusa mini and I cannot flash the ESP firmware.
I updated the printer's firmware (bootloader 2.3.4 and firmware 5.1.2). I installed this wifi module, and I'm trying to do step 3 of this guide (Settings > Network > Wi-Fi > Setup Wi-Fi Module). This fails saying "Firmware flashing failed!"
Is this an issue with the wifi module, or with how I've been doing the setup?
Publié : 06/02/2024 7:41 pm
mixer3d
(@mixer3d)
Hi looks like you choose the wrong module, from the photo it looks different, and  in spec is written that it's just other chip there: SP8684H4 WiFi BLE Module ESP32-C2, what you need is ESP-8266 ESP01s module.
Publié : 08/02/2024 9:20 am
Guigs
(@guigs)
Thanks a lot. Changing the module fixed the issue.
Publié : 13/02/2024 10:29 pm
GM
 GM
(@gm-3)
Membre
Hello,
After upgrading to the 6.0.x firmware I started having issues with the wifi connectivity.
When I first start the printer it does not connect to my local wifi. If I reset the printer I get the prompt to start the configuration of the wifi module, and if I skip it it immediately connects to the wifi.
I tried to go thru the wifi module setup again, if flashed the module, I went thru the setup of the wifi but the issue appears again next time I power on the printer.
Any ideas what I might be missing ?
Publié : 26/06/2024 2:44 pm
Aschirin
(@aschirin)
Membre
I have a similar problem. I've upgraded from 5.1.2+13478 to 6.0.4+14924 yesterday and cannot connect to my network ever since, no matter what I try.
Multiple restarts, flashing the Wi-Fi module, generating and importing the config file, leaving the printer idle for more than 30 minutes at a time and it just does not want to connect.
It worked fine on the older firmware every time. There were no changes to my network so I'm quite convinced the firmware update messed it up.
The only observations I have regarding the indications are:
1. After importing the config the Wi-Fi icon shows gray for like 1s and goes away
2. On each boot the Wi-Fi icon shows white for about 1-2s but then disappears and it doesn't even connect at that time either.
I don't get any errors, it just does not want to connect.
Publié : 02/08/2024 12:52 pm
GM
 GM
(@gm-3)
Membre
With the latest firmware (6.1.2) the issue seems to have disappeared for me.
Publié : 21/09/2024 6:54 pm
RKC
 RKC
(@rkc)
Membre
I bought two modules from Prusa and installed one and am getting the firmware can not flash error on step one. Bootloader and firmware both up to date. I'm going to try the second one tomorrow. But from reading this FAQ, it seems rather frustrating that even using official parts that WiFi is not a solved issue.
Publié : 12/10/2024 1:50 am
habreli
(@habreli)
Same Problem here. I´v a dash in the SSID an the module want connect.
Hoping that prusa will fix this bug soon.
Thanks
Prusa Mini+
Publié : 09/11/2024 10:39 am
habreli
(@habreli)
Replying to myself.
The problem is not the dash in the SSID.
It´s simply that it takes really a long time before a ip address will be assigned.
Prusa Mini+
Publié : 12/11/2024 10:15 am
domble
(@domble)
My Mini+ is on 6.2.0-alpha2+8702.  The WiFi (web page, and access from slicer) doesn't work - doesn't find the printer at all or fails before sending any data.  Does talk to the Prusa android app for status info.  Used to work with previous firmwares, although it was always hit and miss whether it would complete any larger transfers (of bgcode direct from prusa slicer).
The mini is now inside a Prusa enclosure, which may be relevant to signal strength.  I have a genuine Prusa wifi module (left over from work Mk4 -> Mk4S upgrade) to try, haven't got around to that yet.
Am I the only one having trouble?  It's getting my steps count up anyway (up and down stairs too...)
Dom.
Publié : 09/12/2024 2:24 pm
- WESELY -
(@wesely)
Membre
I have Wi-Fi modul in my printer, but when I try to connect to my Wi-Fi it says something like "canˇt connect" and next to is QR code and url like "prusa.io/....". Can anyone please help?
Publié : 04/01/2025 5:18 pm
domble
(@domble)
Replying to myself; my bad.  I actually had a wrong IP address set for the 'physical printer' in prusaslicer.  Connection was flakey previously, but then the PC was replaced and I did a typo.  Having improved the wifi (mesh access point now right next to the enclosure) *and* corrected the IP address it seems to be working properly.  May have been firmware updates during that time too.  Not yet sent a big print to the printer (which was what showed up trouble in the first place).
Now where's the 'embarrassed' smiley... 😯
Ce message a été modifié il y a 11 months par domble
Publié : 07/01/2025 9:56 pm
1 personnes ont aimé
Page 7 / 8
