Prusa Mini+ Making Endstop Clicking Sound on Z Axis
PLivering
(@plivering)
I noticed that my Mini+ had started making a clicking sound while printing after about the 2nd day of use. At first, I thought that it was the hot end but I noticed that it only makes the sound whenever it Z Hops, but not when I move the Axis up or down only while it is hopping. I tightened the Z-Axis motor and the bolts that attach the large bolt to the plastic pieces that move the X-Axis but the clicking is still there. It sounds almost exactly to an endstop you might find on an Ender 3 whenever the bed maxes out on the X, Y, or Z but I know that Prusa does not use end stops like these.
Clicking
Napsal : 28/02/2021 4:38 pm
Turro75
(@turro75)
RE: Prusa Mini+ Making Endstop Clicking Sound on Z Axis
that click comes from the extruder during retraction, search in the forum, there is plenty of post about this
Napsal : 28/02/2021 10:19 pm
sandysasmita
(@sandysasmita)
Sometimes bad (wet) filament can cause clicking noise (popping) while printing. Try to drying your filament and test again.
Napsal : 02/03/2021 8:36 pm
