Prusa mini bricked by FW update
Printerman
(@printerman-3)
I tried to update my Prusa mini from the 4.4.1 firmware to the 5.1, the Mini did accept the update but afterwards it doesnt start, i only get the bootloader sign, after that i get this.
Napsal : 06/12/2023 2:46 pm
Printerman
(@printerman-3)
RE: Prusa mini bricked by FW update
I discovered what i did wrong, i only copied one of the firmware files, not all of them like i should have done. I managed to re-install older firmware using the reset and double click method, and then re-installed the new firmware 🙂
Napsal : 06/12/2023 3:13 pm
1 lidem se líbí
BlackFury
(@blackfury)
Thank you! Did the same mistake and couldn't find a solution..
Napsal : 17/12/2023 9:21 am
1 lidem se líbí
