Prusa Mini Appendix Firmware question
Foxytisy
(@foxytisy)
So, I had a problem where I wanted to modify some icons in the Prusa firmware. I did that, compiled it as a .bbf all of that stuff. But when I flashed it on the Prusa USB stick and stuck it in the printer and pressed the reset button but when I flashed it on my printer it said "VERIFICATION FAILED" I searched up why that is happening and I found out that I have to cut the Appendix and lose my warranty for the printer. I really didn't want to tinker with the printer physically and lose my warranty for it.
Is there any way to bypass or at least not lose my warranty for installing official Prusa Firmware but with some png file tweaks?
Best Answer by Sp4rkR4t:
No you have to cut the tab, anyway the mini's warranty isn't worth it any way, all the likely suspects to cause a big issue aren't covered anyway. Go rogue, go klipper.
Veröffentlicht : 02/01/2022 5:07 pm
Sp4rkR4t
(@sp4rkr4t)
RE: Prusa Mini Appendix Firmware question
Veröffentlicht : 02/01/2022 5:20 pm
Foxytisy gefällt das
