Prusa Mini and ESP-01(S) module - installation
MartinD
(@martind)
Hello, I just received ESP-01S module, and I want to install it to my Prusa Mini, does someone have any photos which side I have to install it and to which connector?
Can also someone confirm, that wifi module is not working yet, or is it? If it is working how to configure it etc.
Tried to search forum, find nothing.
Napsal : 27/05/2020 12:29 pm
Oxygen
(@oxygen)
RE: Prusa Mini and ESP-01(S) module - installation
You can install it anyway you want, because it is not supported at this moment -- devs said somewhere this summer
(there is only one way the board can be placed int the board)
Stock MK4S with FW 6.2.6
Napsal : 27/05/2020 1:49 pm
Gordon W
(@gordon-w)
The support for WiFI isn't included currently, last I heard it was due "in the summer".  As far as a picture goes, the best I've seen is this one from the original announcement ( https://blog.prusaprinters.org/original-prusa-mini-is-here-smart-and-compact-3d-printer_30887/ ). Perdsonally I wouldn't install the module just yet, can't see anything going wrong, but just in case ... 🙂
Napsal : 27/05/2020 1:55 pm
Oxygen
(@oxygen)
i Have seen a video where the module is placed like this
but the module will not work -- the buddy board must reprogram the ESP01 so it can function as a WiFi receiver module -- that code is not in the current firmware
Napsal : 27/05/2020 2:28 pm
MartinD
(@martind)
Thank you very much!
Napsal : 27/05/2020 3:05 pm
Gordon W
(@gordon-w)
You might get updates on when the capability will be released if you watch this issue: https://github.com/prusa3d/Prusa-Firmware-Buddy/issues/412 but equally it might just appear in a future version 😀
Napsal : 27/05/2020 3:19 pm
1 lidem se líbí
BrettG
(@brettg)
Posted by: @martind
Did you ever find a solution
Napsal : 21/06/2021 3:46 pm
