Problem with Hotend, material comes from the top
Maveg CZ
(@maveg-cz)
Hi, I'm fighting last 2 days with a new problem, that I didn't encounter yet. Look at my PLA prints:
By the first print (right) was the printer a couple of times in use without problems. I stopped the print and realized, that the 0.4 nozzle is full with PLA. I removed it for a clean one. I did a cold pull and also cleaned a feeding mechanism, especially feeding gear, which was full of PLA. So I put everything together, started a calibration in Z axis and then printed the same part again with prusa slicer recommended speed ans temperature settings. It started really nice like the last time, but after a while, there was the same problem.
Now I have the material coming from the top of the hotend:
Could it be, that I pulled the hotend from the cooler or what might be the problem?
I removed the filament from the printer and PLA from the top of the hotend, when it was still hot.
Respondido : 17/03/2026 9:44 am
Pay particular attention to the diagrams at the bottom of this page:
https://help.prusa3d.com/article/changing-replacing-the-nozzle-mini_134235
As you are experienced a simple fitting error is unlikely but there are cheap 'clone' nozzles available that are a fraction short in the thread making them impossible to fit correctly;  sometimes these are sold as genuine E3D parts by unscrupulous traders...
Respondido : 18/03/2026 2:07 am
