Print will end today at... the wrong time
RJ
 RJ
(@rj)
Since the last firmware update I have now been able to see the "Print will end today at" time on the display, however it appears to be based on UTC time (maybe) vs my local time zone.
When I check the "Estimated end" time from the Prusa Connect web console, it displays the proper estimated time zone adjusted end time.
I have been through all (I think) the menus and don't see where or how to change.
What am I missing?
Respondido : 30/11/2020 5:35 am
Area51
(@area51)
Miembro
RE: Print will end today at... the wrong time
I think this bug is reported on GitHub: [BUG]Printing time display error #1088
Respondido : 01/12/2020 12:37 am
RJ
 RJ
(@rj)
@area51
Looks close.... but either he is running newer or older firmware as my display is "Print will end today at" in the same location this one is "Remaining Time".
Had did look into the gcode and looked for any "time zone" information - did not find any...  will spend a bit more time digging and if nothing else - will submit a bug report.  As i remember 4.0.5 firmware provided the correct "Remaining time" where as 4.1.0 changed it up to provide an estimated "End" time.
Thanks for the reply!
Respondido : 02/12/2020 12:52 am
RJ
 RJ
(@rj)
Ok - found the issue - when the firmware updated it must have wiped all the prior settings (It was a bumpy update for some reason) and I looks like I missed resetting the "TZ (UTC)" setting...
Back to your regularly scheduled printing...
Respondido : 02/12/2020 1:03 am
