PLA glued to hotend
Dear all,
After last night's print the PLA was glued to the hotend. Not sure how this could happen. I was able to get rid of the PLA below the hotend with the nozzle set to 260 degrees. Unfortunately the PLA above the nozzle is strongly glued to the hotend, I can't detach it (Please see picture below).
I couldn't find a similar case on this forum unfortunately? Does anyone have experience with this case and how to detach the PLA?
Respondido : 27/09/2022 5:32 pm
RE: PLA glued to hotend
Heat it up and try to remove it with tweezers. Be careful, it will be very hot.
You also might have a leak.
Respondido : 28/09/2022 10:26 am
1 les gusta
