overflow after nozzle change
KTH
 KTH
(@kth)
I changed to a ruby 0.8mm and it leak at top of nozzle and heat break
I have screw in the nozzle as close to the heat block as possible and I still get overflow.
what should i do?
https://help.prusa3d.com/en/article/changing-replacing-the-nozzle-mini_134235
Thanks
Best Answer by KTH:
it was still leaking.
so i reseated heatbreak, heatblock and nozzle.
end up changing to a new heatbreak and heatblock as it was a pain to remove&put back the other parts.
hopefully it does not leak now.
Leason learnt:
Do not change nozzle unless you want to have the change to reseat the whole thing.
Postato : 26/12/2021 1:11 pm
On that page pay particular attention to the diagrams marked 'Final Inspection'.
Postato : 26/12/2021 5:37 pm
RE: overflow after nozzle change
Your heat break may not be screwed in deep enough to form a seal.
Postato : 26/12/2021 7:28 pm
KTH
 KTH
(@kth)
i screw in even more n having a LITTLE gap left.
that solves it.
i was planning to reseat the whole thing if this does not work. luckily it worked.
thanks everyone.
Postato : 27/12/2021 8:14 am
KTH
 KTH
(@kth)
Leason learnt:
Postato : 28/12/2021 4:08 pm
