Nozzle Swap and Resetting the Z on Multiple Steel Sheet Profiloes
Razor
(@razor)
So I swapped my first nozzle out today and re-ran my first layer calibration using my smooth steel sheet. Do I have to run the calibration on my other stored sheets as well? Or, does the system automatically calculate a new Z from the delta in the smooth calibration, and apply it to my other stored profiles e.g., satin and textured sheets?
Thanks!
Best Answer by FoxRun3D:
It doesn't. You need to redo it for every sheet.
Mini+MK3S+XL 5 Tool
Napsal : 16/12/2022 8:17 pm
RE: Nozzle Swap and Resetting the Z on Multiple Steel Sheet Profiloes
Napsal : 16/12/2022 8:28 pm
1 lidem se líbí
Thomas Lynch
(@thomas-lynch)
You need to calibrate the new Z for each sheet. It only stores the info for the sheet you calibrated.  I have calibrations for each of the sheets (smooth and textured) that I use and it works quite well. There are slight differences in each sheet.
Tom
Napsal : 16/12/2022 8:29 pm
Razor
(@razor)
Thanks guys. That’s what I figured, but hoping I was wrong. 😉
Mini+MK3S+XL 5 Tool
Napsal : 16/12/2022 8:47 pm
