Nozzle and Print Bed Keep Heating After Filament Unload or Filament Load
Klaus Krämer
(@klaus-kramer)
As my new Prusa Mini+ is an addition to my first filament printer (UM3) I am wondering why unloading or loading filament is
  • accompanied by heating the print bed
  • followed by steadily heating the nozzle AND print bed, after filament has been loaded or unloaded
I cannot see the purpose (and the UM3 only heats the nozzle for the sole process of filament loading)
Postato : 30/11/2022 6:28 am
RE: Nozzle and Print Bed Keep Heating After Filament Unload or Filament Load
Well, you're not alone wondering. I can see the point of keeping the nozzle at operating temperature because more often than not you may load another filament to continue. (plus, it will turn heating off after a while anyway). But heating the bed feels like a waste of energy.
Postato : 30/11/2022 12:04 pm
Klaus Krämer
(@klaus-kramer)
I had been waiting for about 20 minutes, but I lost patience then and pressed the reset button ...
Ok, your thought about color change isn't so farfetched, but even then the firmware should know whether a print is pending or not.
Postato : 30/11/2022 12:31 pm
Frog
 Frog
(@frog)
I've been wondering for years 🤥 Prusa uses the Mini in a print farm. So they probably profit themselves but for normal users this is only waisting energy.
Postato : 05/12/2022 8:53 am
1 persone hanno apprezzato
Tadas
(@tadas)
I know this is an old post, but i'm having the same problem, after unloading and loading new filament, my prusa mk3/s does not cool down, if that's how it should work - how long does it take for printer to "understand" that its not printing anything and start cooling down? atm after i load new filament i press the reset button, but it feels like a hack 🙁
Postato : 03/01/2024 5:33 pm
I don't know the Mini but:
the last entry in the Preheat menu is Cooldown...
'though I have trouble thinking of a reason to cooldown after loading.
Postato : 03/01/2024 7:55 pm
With newer firmware there's also an option under User Interface not to heat the bed during filament changes.
Postato : 03/01/2024 8:00 pm
Frog
 Frog
(@frog)
Maybe we could have an additional menu position: "Unload filament and stop printing"?
Postato : 03/01/2024 8:08 pm
