New Gcodes not visible on Mini
PolkaDotson
(@polkadotson)
When I plug my Prusa provided thumb drive into the mini, it recognizes the drive and it can read gcodes that I've made prior to today. However, the new gcode that I just made with the Prusa slicer, in the exact same manner as always. The gcode is viewable in file explorer on the computer and the desktop version of gcode previewer can open it without any problems from the drive. I've double checked and it's the correct file type, though again, I'm not doing anything different than I've done in the past.
Any thoughts or advice? Can I reformat the drive? If so is there something I might need to do for it to then speak to the printer appropriately?
Thanks,
Publié : 22/09/2021 7:30 pm
PolkaDotson
(@polkadotson)
Update
So, in looking for work arounds, I've found that if I save the gcode to the PC and then move it to the flash drive instead of saving directly to the drive the printer recognizes the gcode just fine. This is really puzzling.
Publié : 22/09/2021 7:53 pm
geekandi
(@geekandi)
Membre
Line ending encoding?
Posted by: @polkadotson
Potentially something going on with line-endings between MSDOS (CR/LF), UNIX (LF), or something like that?
just random ideas.
Publié : 22/09/2021 8:29 pm
Write caching shouldn't be a problem anymore on modern PCs but you can try to see if hitting the eject button in Prusaslicer before you remove the stick helps. It should flush the write cache.
Publié : 23/09/2021 11:38 am
PolkaDotson
(@polkadotson)
Eject Drive Button
I always do and, in trying to figure it out, I tested both with and without ejecting and got the same result. Older gcodes visible, ones from [yesterday] were not.
Publié : 23/09/2021 2:00 pm
cloudbuster
(@cloudbuster)
RE: New Gcodes not visible on Mini
This did it for me. Eject the drive through the slicer. Thank you!
Posted by: @fuchsr
Publié : 12/01/2022 2:20 pm
dharmix
(@dharmix)
I'm having the same issue, did you solve the problem?
Publié : 20/09/2022 7:02 am
Snuups
(@snuups)
Posted by: @dharmix
Probably not. I can't print an any Mini anymore. Whatever I do the files are not shown.
Publié : 10/01/2024 7:53 pm
Are your Minis on the latest firmware version?
Publié : 10/01/2024 8:33 pm
1 personnes ont aimé
Snuups
(@snuups)
Thank you Fuchsr
I was not. The Mini was also not naging about not having the latest FW. Now it works. Do the printers not mention that there are new FW anymore?
Publié : 10/01/2024 9:23 pm
The latest Mini printer profiles don't have anything in the startup gcode that tells the printer what the current firmware version is.
This whole transition to bgcode and the new image format was not one of Prusa's finest moment. Everything felt rushed, probably because of the heat they were getting for the pathetic network upload speeds.
Publié : 10/01/2024 10:07 pm
Šimun Galović
(@simun-galovic)
Membre
Hi I have a same problem, have you solved it??
Publié : 17/05/2024 3:57 pm
Baryprint
(@baryprint)
Membre
I used flash that came with prusa to instal liberElec and after reformating it back to normal prusa just wouldnt see any files on it. As it turn out the formating proces swithced the flash to GPT (GUID Partition Table) that prusa cant deal with. You need to format the flash back to MBR (Master boot record). I used rufus to format flash to MBR in no problem since then.
Publié : 29/09/2024 6:46 am
