Needing help with Flow/ironing correction
I'm recently new here, and have been searching around, and I found that some of the small gaps I'm having in my top layers with Ironing enabled could be due to a needed correction in the Flow Rate.
I looked around and started by measuring 100mm of filament and ordering it to extrude those 100mm but only 87mm were extruded.
Now I've seen there is some math to do in order to adjust this on Prusa Slicer, right?
But is there no way to adjust the new settings on the Prusa printer itself, and test the 100mm extrusion again until it is correct? without the need to get some 3d object to be printed I mean.
Am I even in the correct path/mindset, of what I should be doing to correct the small ironing gaps?
Thank you in advance for any help 🙂
Napsal : 08/01/2022 2:29 pm
