Need help with layer variablity / shifting
Ed
 Ed
(@ed-19)
I have been running these units on and off production for last couple of years and this issue started first on one machine but now effects both equally. Both machines purchases new (direct from prusa assembled). A couple dozen kilos of filament through each.
I have to fix this issue as these machine prints are unusable for my application.
Any thoughts would be appreciated.
Posted : 05/04/2024 6:04 pm
First thought: check belt tensions.
https://www.prusaprinters.org/prints/46639-tension-meter-for-the-gt2-belts-of-i3-mk3s-or-prus
It MUST be printed in Prusament PETG or the spring tension will be wrong.
Posted : 05/04/2024 10:52 pm
Ed
 Ed
(@ed-19)
RE: Need help with layer variablity / shifting
Thanks for the link to the tension gage. Unfortunately I don't have any Prusa PETG to run the test fixture. Rechecking tension (on both machines)  it appears that they are a bit too tight and I loosened the belt and am running a Benchy on each.
Posted : 06/04/2024 12:06 am
_KaszpiR_
(@_kaszpir_)
Afair that's the amount that the stock nozzles start to wear out.
Or belts/screws getting loose, check them and tighten them.
Posted : 06/04/2024 7:29 pm
Ed
 Ed
(@ed-19)
The relaxed tension on the x-axis belt seemed to make the benchy look better but still way too many horizonal stacking errors.
I will change ou the nozzles and run another benchy. I am starting to see some stringing so they could use a fresh nozzle.
Posted : 06/04/2024 9:03 pm
OK, have you worked though this:
Mini - https://help.prusa3d.com/en/article/regular-maintenance-mini_133222
Posted : 07/04/2024 12:07 am
Ed
 Ed
(@ed-19)
Thanks for the link. I have done all the things on the list except change the nozzle and update to the latest firmware. I will change out nozzles in the morning.
Posted : 07/04/2024 1:20 am
Although the nozzle may be worn - which would contribute, I would tend to suspect smooth rod cleanliness and lubrication which you have just addressed, or, failing that, something  wrong with an idler pulley.
Posted : 07/04/2024 3:36 pm
Ed
 Ed
(@ed-19)
The new nozzle made no appreciable difference in the print quality. The biggest improvement came from reduction in belt tension. I think that your idea about the idler may be the last potential issue. I have replacement idler pulleys so I will try... I am not looking forward to tearing these two mini's apart to replace the idler pulley. :(.
Posted : 07/04/2024 8:50 pm
You may not need to replace them - if you're lucky there will be a few wisps of filament jamming them - loosen the belts and try to move them with your fingertip - are they smooth?  They may be out of line and rubbing against the housing - if so adjust or maybe print a new housing.
While you have the tension off try turning the stepper motors by hand, you will feel the steps but otherwise they should be smooth.  Make sure the stepper pulleys are not slipping.
Posted : 08/04/2024 12:34 am
