monitoring via serial info not working - M73
Hello,
I create a python script to monitor printing, like this I can show the current layer number on a custom webpage. In the new firmware release (6.0.3), I saw that the command M73 have been handled, so I try it in my script. When the script send the M73 command on the serial port, the printer answer this :
M73 Progress: 5% Time left: 0m Change: 10m
The progress is correct but time left is always 0m and the next time change is not updated, it's always the time between the begining and the first change.
Do you think I need to open a ticket on the firmware github or do you have any solution ?
Best Answer by nxnSamy:
the bug is handle by this ticket -> https://github.com/prusa3d/Prusa-Firmware-Buddy/issues/4089
RE: monitoring via serial info not working - M73
