Mini no longer recognizes USB drives
Steve Drees
(@steve-drees)
Attempting to upgrade the firmware (Currently on 4.3.1)
Trying to update to 4.41 initially. Using the usb drive that came with the Mini. I get Error #2 on restart with doubble press of the select button. No double press the 4.3.1 firmware loads but says No USB drive.
Tried 2 other usbdrives formatted FAT32 with identical results. What should I try next?
Postato : 03/05/2024 11:58 pm
_KaszpiR_
(@_kaszpir_)
RE: Mini no longer recognizes USB drives
Did you try this https://help.prusa3d.com/article/usb-not-detected-mini-mini_230441 ?
Postato : 04/05/2024 12:07 pm
Steve Drees
(@steve-drees)
I've tried all but the "update firmware" suggestion. Updating the firmware is what I was attempting to do when I noticed that my mini wasn't ever seeing the USB drive.
I've tried multiple USB drives, including the one that came with the mini. I've formatted as FAT32. And still they are not recognized.
Postato : 04/05/2024 4:16 pm
Steve Drees
(@steve-drees)
My bootloader version is 1.0.0 in case that matters.
Postato : 04/05/2024 4:18 pm
Steve Drees
(@steve-drees)
Decided to punt and ordered a replacement Buddy Board.
Postato : 28/05/2024 1:27 pm
Steve Drees
(@steve-drees)
Replaced the Buddy Board and I can once again read USB drives.
Postato : 17/06/2024 3:38 pm
_KaszpiR_
(@_kaszpir_)
So probably USB port was damaged.
Postato : 18/06/2024 6:50 am
1 persone hanno apprezzato
Steve Drees
(@steve-drees)
Solder joints for the port all look clean. Contact points in the port look good as well. Labeled the board as "bad usb port" and stored it away as an emergency spare.
Postato : 18/06/2024 3:27 pm
