MINI heat block fan replacement PWM and voltage
Patrik Zak
(@patrik-zak)
Hello,
I am looking into replacing the stock heat block fan on the MINI.
I figured the stock fan is 5V.
mini heater block fan
Which one of these would work?
3-pin 5V
https://www.alza.sk/noctua-nf-a4x10-5v-d5464098.htm?o=33
4-pin PWM 5v
https://www.alza.sk/noctua-nf-a4x10-5v-pwm-d5716009.htm?o=41
Does anyone know which one I should buy?
Thanks!
Best Answer by JoanTabb:
Posted by: @hl2run
3-pin 5V
4-pin PWM 5v
Thanks!
Hi, you appear to have your fan in front of you!,
How many wires does it have?
I suspect the answer is three, but I don't have a mini, to confirm
Regards Joan
This topic was modified 6 years temu 4 times by Patrik Zak
Opublikowany : 05/02/2020 6:20 pm
RE: MINI heat block fan replacement PWM and voltage
Posted by: @hl2run
3-pin 5V
4-pin PWM 5v
Thanks!
Regards Joan
Opublikowany : 05/02/2020 7:21 pm
1 ludzie polubili
Clemens M.
(@clemens-m)
I had a broken fan on my Prusa i3 MK2.5S and wanted to replace it. Be aware that you by a fan with same rotational speed as the original. With the replacement (the MK2.5S has only 3 pins) I had lots of issues during printing because of "wrong" cooling. I ended up bying an official fan from Prusa.
Best regards, Clemens Mödlin
Opublikowany : 05/02/2020 7:50 pm
1 ludzie polubili
Patrik Zak
(@patrik-zak)
@joantabb
Correct, 3 wires, but I was just not sure.
Thanks a bunch!
Opublikowany : 06/02/2020 5:59 am
@hl2run
As far as I am aware the 4 wire fans, need an active PWM signal to be pumped into the fan, to drive the fan motor controller. which is a feature I have not seen on a 3D printer...   but then I have not got my hands on a Mini yet, so have little idea what the 32 bit controller can achieve.
Opublikowany : 06/02/2020 9:55 am
3Dprintedgr
(@3dprintedgr)
Posted by: @hl2run
Hello,
3-pin 5V
4-pin PWM 5v
Thanks!
I would not recommend any of the fans you are showing here. With a quick search you can see that the characteristics are way different. If you wanted it for a pc air flow it may would be sufficient but in the case of a 3D printer it will cause many problems with layers.
Key differences:
  • While the rpm on Delta (Mini original) fan is 8000rpm the Noctua has 4500rpm.
  • Also the rated input current on the Delta is 0.11A  while on the Noctua is half 0.05A.
  • The most important characteristic is the air flow which in the case of Delta is 0.262 cubic meters/min while the Noctua has  0.1366 cubic meters/min which is again half. This means it cannot provide the same air flow to your 3D prints.
This post was modified 6 years temu by 3Dprintedgr
Original Prusa Mini + Smooth PEI
Prusa Slicer 2.6.0
Opublikowany : 07/02/2020 6:53 pm
1 ludzie polubili
3Dprintedgr
(@3dprintedgr)
First time uploading pics 😋
Here are the datasheets from both fans. So I would recommend searching for a fan with the blue characteristics above.
Prusa Slicer 2.6.0
Opublikowany : 07/02/2020 7:04 pm
1 ludzie polubili
Patrik Zak
(@patrik-zak)
@geoper2
Thanks so much! The Delta fan is really noisy, so I will look for other suitable replacement.
Opublikowany : 07/02/2020 8:51 pm
Crawlerin
(@crawlerin)
@hl2run
Have you managed to find suitable fan?
Opublikowany : 20/02/2020 6:51 pm
Patrik Zak
(@patrik-zak)
@crawlerin
Nope :(, crawled whole aliexpress with no luck.
Opublikowany : 20/02/2020 6:52 pm
Argh
 Argh
(@argh)
Posted by: @hl2run
@crawlerin
Do you think this one would work? Specs are close bit a bit more CFM and power.
https://www.digikey.com/product-detail/en/cui-devices/CFM-4010-03-20/102-4398-ND/6194962?utm_adgroup=DC%20Fans&utm_source=google&utm_medium=cpc&utm_campaign=Shopping_Fans%2C%20Thermal%20Management_NEW&utm_term=&utm_content=DC%20Fans&gclid=CjwKCAjwr7X4BRA4EiwAUXjbt7z9szkQ0NFe9mXGkj7720Vk6i3VbSVI24yc2xdK9bG8p4Gd1Icb7RoCDuwQAvD_BwE
Opublikowany : 15/07/2020 1:08 am
Ambulocetus
(@ambulocetus)
Any updates on finding a quiet replacement fan? Bit of a shame noctua ones wont work
Opublikowany : 28/09/2020 6:01 am
Patrik Zak
(@patrik-zak)
@tobz4321
nope
Opublikowany : 28/09/2020 6:04 am
I have these on both my MK3S and Mini: FTSETC Fans.  I also have a Noctua 3 pin 5V on a printer.  The Noctua is quieter and appears to cool sufficiently.
Opublikowany : 28/09/2020 2:17 pm
1 ludzie polubili
