Mini+ Filiment Sensor is not recognized
Joseph
(@joseph-4)
During initial setup and calibration, I believe the printer is supposed to ask if the filiment sensor is installed (per Josef's video).  Mine does not.  I have checked that the installation of the filiment sensor is correct.  Any suggestions?
Postato : 04/05/2021 11:36 am
RE: Mini+ Filiment Sensor is not recognized
It's been a while since I installed a sensor but I believe it should just work. I think there's also a setting under Settings to turn the sensor on or off.
Postato : 04/05/2021 6:31 pm
Posted by: @joseph-4
Have you installed the latest firmware and activated the sensor in the menu?
https://help.prusa3d.com/en/article/noisy-filament-sensor-mini_162222
Postato : 04/05/2021 8:46 pm
Joseph
(@joseph-4)
@fuchsr
Thanks for answering.  The filiment sensor is turned on. I wonder if the video is just out of date, and setup no longer includes the question about having the filiment sensor or not.
Postato : 05/05/2021 12:17 pm
Joseph
(@joseph-4)
@karl-herbert
Thanks for answering.  The firmware is current, and the filiment sensor is on (so clearly the machine recognizes it).  I wonder if the video is just out-of-date and the setup routine no longer asks about the filiment sensor.
Postato : 05/05/2021 12:19 pm
Utenti
Mine does not ask either.
Postato : 05/05/2021 5:08 pm
Joseph
(@joseph-4)
@cwbullet
Thanks for replying.  I think the video is out of date and the setup routine has changed.
Postato : 05/05/2021 5:29 pm
@cwbullet
My printer checks for missing filament and reacts accordingly on the LCD. Reloading a filament roll that has run out also works perfectly.
I still have installed firmware 4.2.0.
Postato : 05/05/2021 6:15 pm
Postato : 05/05/2021 6:16 pm
