MINI+ crashes after Firmware 5 update
bg1627
(@bg1627)
I updated the firmware to 5.1.0-alpha1, and the printer freezes and crashes when trying to select a gcode to print in the printer interface. I noticed that shorter, smaller prints do actually print, but everything else crashes after selecting the file.
I'm somewhat new to this, so it's totally possible I updated the firmware incorrectly. I deleted the .bbf files and uploaded the latest .bbf file to the flash drive. Everything flashed and updated correctly, from what I could tell.
Any help you can give would be great. If you need more info, let me know.
Thanks!
Opublikowany : 21/09/2023 2:03 am
Kraut55
(@kraut55)
RE: MINI+ crashes after Firmware 5 update
Same here. unable to print anything, always crashes.
Opublikowany : 22/09/2023 2:57 pm
Have you reported this on GitHub? The devs probably won't see it here.
Opublikowany : 22/09/2023 3:53 pm
JP
 JP
(@jp-6)
Wechselt mal den USB Stick und probiert noch einmal upzudaten.
Opublikowany : 22/09/2023 8:33 pm
bg1627
(@bg1627)
Ah ok. Thanks!
Opublikowany : 22/09/2023 8:59 pm
bg1627
(@bg1627)
Do you mean use a completely different USB stick?
Posted by: @gcoupe16v
Opublikowany : 23/09/2023 12:25 am
bg1627
(@bg1627)
Looks like it might have to do with files not in the root directory.
Opublikowany : 23/09/2023 12:32 am
JP
 JP
(@jp-6)
Yes, take a complette different USB stick, put the update on it and try again updating. This problem i had when I tried to insall the 4.4.1 firmware.
Opublikowany : 24/09/2023 6:43 pm
