[Resuelto] MINI bowden tube adapter/alternative
keithywhites
(@keithywhites)
i hate the stock bowden tube connection, and want to use the standard quick connect setup. i modified the extruder back piece to fit the 10mm thread for the boden fitting.  looking for a solution to connect it at the heat sync.  its 8mm thread.  anyone have a solution?
Respondido : 17/02/2021 1:14 am
morp
 morp
(@morp)
RE: MINI bowden tube adapter/alternative
Buy PC4-M8 bowden couplers, or print your own adapter. See here:
https://forum.prusa3d.com/forum/user-mods-octoprint-enclosures-nozzles/pc4-m8x1-25-bowden-pneumatic-connectors/
Respondido : 17/02/2021 4:34 am
I replaced all the Bowden tube connections with pneumatic couplers, arguably the most useful mod I did. For hotend to extruder connection, I used these PC4-M8 connectors: https://www.amazon.com/gp/product/B07QFK7YWP
I tried the 3D printed adapters, but ended up shearing off the thread while tightening (and no, I didn't put much force in) and had to buy a new heat sink 🙁 My recommendation is, why risk it—the brass connectors are cheap enough and guaranteed to be sturdier.
Respondido : 17/02/2021 11:26 am
Miembro
@fuchsr
Yup.  That is common for folks to install them into plumming and shear them.
Respondido : 17/02/2021 11:43 am
Oxygen
(@oxygen)
That is what I did, I replaced all 3 parts of the boden-tube and replaced it by 1 piece from extruder to nozzle with the help of 2 bowden couplers
Stock MK4S with FW 6.2.6
Respondido : 17/02/2021 11:57 am
Miembro
@oxygen
Same here.  I do them more useful but sometimes the ptfe is difficult to remove.
Respondido : 17/02/2021 1:40 pm
keithywhites
(@keithywhites)
thanks everyone, after searching PC4-M8, i was able to get some ordered!
Respondido : 18/02/2021 3:37 pm
singlefin
(@singlefin)
Thinking of replacing all the ptfe tubing with one long piece as you had done.  Does the length of tubing have to be exact? What should the total length be? Thanks!
Respondido : 31/12/2021 5:39 pm
I just eyeballed it to roughly the length of the current tube and the two small pieces.   . Plenty of material that gets pushed out when purging so I didn't see the need for precision.
Respondido : 31/12/2021 5:50 pm
Sp4rkR4t
(@sp4rkr4t)
I've been searching for PC4-M8 trachea connectors that I can get shipped to the UK all evening with no joy, did you lot buy them all up? 😛
Respondido : 31/12/2021 9:33 pm
lurc
 lurc
(@lurc)
Dang I must have lost my mind.
I know there is one 275mm tube that goes from the extruder to the top of the print head....  And there is the small 42mm tube that goes from print head into the nozzle .... but what third tube are you guys talking about?
Respondido : 14/01/2022 4:24 pm
Sp4rkR4t
(@sp4rkr4t)
Third one is inside extruder.
Respondido : 14/01/2022 4:28 pm
Crawlerin
(@crawlerin)
There is short PTFE tube inside extruder as well.
Interesting, I did it the other way around, I bought original heatsink for  cloned MINI, and I drilled and tapped Bownden collet for BMG extruder with M8 thread, to be able to use original fittings. (I slapped standard non-MINI version of BMG extruder on it).
Esta publicación ha sido modificada el hace 4 years 2 veces por Crawlerin
Respondido : 16/01/2022 12:25 am
