Mini+ bed leveling 2
29e1e4
(@29e1e4)
I have a problem with my 1st layer. As far as I looked on the internet, it is probably that the printing sheet (original Prusa mini structured steel sheet) is not level (see pictures - the steel sheet was thoroughly cleaned before). So my question: is there a possibility to tighten the mesh of the auto mesh bed leveling? Now, it probes 16 points. Is it possible to set a tighter mesh, say, to probe 64 points? By the way, I did the xz-axis skew correction (see my old post here: https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/mini-bed-levelling/).
Or, could the problem be somewhere else? I wanted to install the Octoprint bed visualizer to go sure about my assumption, but I have no Raspberry at hand right now...  Any hints appreciated 🙂
Napsal : 14/08/2021 8:11 am
Tighter Mesh
I think you would have to program your own firmware to do something like that.
I was able to get past this with a day of printing full sheet first layer adjustment.
Napsal : 14/08/2021 12:59 pm
