mesh bed leveling failed and z axis leveling cannot be adjusted
Ecology rules
(@ecology-rules)
during the mesh bed leveling the nozzle got too close to the bed and it made a little scar.
We do not know how to get the nozzle higher and we are scared to run the test again
Napsal : 07/11/2020 9:40 am
RE: mesh bed leveling failed and z axis leveling cannot be adjusted
Posted by: @risastindl
You must first make sure that the printing bed is reasonably well levelled and that the axes, e.g. the X-axis is parallel to the printing bed.
Additionally I would check the flatness with a ruler.
Prusa also offers some support on their help pages:
https://help.prusa3d.com/en/article/first-layer-calibration_112364
It's important to adjust the Z column well (do not tighten the screws too much). The left side, where the tension pulley is located, will also tend to twist and shifts the height of the nozzle. However, the Mini should be able to compensate the bed surface up to 0.5mm.
Napsal : 07/11/2020 2:40 pm
John Crutcher
(@john-crutcher)
the problem sounds like the z sensor is mounted too high in the housing.  My suggestion is to manually lower the nozzle to the bed while having the sensor loose in housing. move two sheets of paper under the sensor, then tighten in housing. This should bring you to within fine tuning range.
Napsal : 13/11/2020 6:56 pm
