Measured temp not matching
Warner Hedgehog
(@warner-hedgehog)
Membre
Hi
I've had my Mini since December last year and all was fine until a couple of days ago. All of a sudden its not a happy bunny, saying "Measured temperature is not matching expected value. Check the thermistor in contact with the hotend. In case of damage, replace it."
Seeing as I have hardly touched the hotend, I would presume the thermistor is damaged.  I have run the self-test and that seemed ok.
I have to say I am not relishing having to dismantle the print head, but if needs must...
Publié : 21/07/2023 2:58 pm
Other than part failures there are a few other possible causes, eliminate them first.
Is your printer in a draft - by a window or door that is not usually open..?
Have you recently turned on air conditioning?
and check that all the plugs and connectors are clean and properly inserted - pull and reseat them all in case some resistant corrosion is interfering with the sensor currents.
If these don't help then, yes, it's time to break out the toolkit.
Publié : 21/07/2023 5:31 pm
Hello
(@hello)
RE: Measured temp not matching
Contact prusa support they will send new part and give you a guide
Publié : 21/07/2023 8:07 pm
Warner Hedgehog
(@warner-hedgehog)
Membre
Solved it! Thanks to a long chat with tech support, it turned out that the thermistor had simply moved a bit. No new parts required.
Publié : 26/07/2023 8:48 pm
