Material Discrepancies (beginner)
BrunoSouth
(@brunosouth)
Membre
Hi. I am new with Prusa, using a Mini at work, and I realized although PrusaSlicer is set to PETG
The Printer shows PLA in the settings. Still seems to work fine, but I wonder if it will work better using the proper material settings.
Publié : 12/01/2024 7:53 am
RE: Material Discrepancies (beginner)
I believe the printer setting is a memory jogger to encourage you to selectt he correct filament settings in Prusa slicer...
Similar to the nozzle size check.
As far as I am aware the printer does not change the settings relative to the slicer defined filament
Personally I find the LCD prompt confusing and irritating..
However I have also set slicer to PLA, and installed PETG filament on the printer, and then wondered why I was getting print fails.
Regards Joan
Publié : 12/01/2024 4:19 pm
