markings on deliveried mini noozle?
pingu
(@pingu)
did your mounted mini noozle had any markinks? mine had none, witch would mean as e3d marks their noozles, 0,25 mm diameter.
just woundering. had massive underextrusion problems, and changed to an original e3d 0,4 mm noozle ( with 3 markings on it) and it gotten better...
Respondido : 14/01/2020 5:26 pm
RE: markings on deliveried mini noozle?
E3D 0.25mm nozzle have no markings, see here:
V6_nozzles
Did you adjust the values in Slicer Software for a 0.25 nozzle?
Respondido : 14/01/2020 7:00 pm
pingu
(@pingu)
i think you didnt get me right. the original noozle the prusa was delivered to me had NO markings on it
if prusa hadn swapped to cheaper noozles with missing markings this would mean that my noozle was a 0,25
Respondido : 14/01/2020 7:25 pm
Write to Prusa support over chat. They will send you the right standard 0.4mm nozzle with 3 markings.
Respondido : 14/01/2020 7:38 pm
PengLord
(@penglord)
My 0.4mm nozzle has no markings. I also thought it was odd that Prusa was using non-E3D nozzles (even though they aren't using an E3D hotend).
I swapped the nozzle to an official E3D  0.25mm last night and can verify that they are perfectly similar with thread depth and I didn't need to tweak my Z-height at all.
Respondido : 15/01/2020 10:49 am
