Manually Moving Bed Issue
Sayum
(@sayum)
I just noticed something on my mini, which i'm not sure is a known issue or not but figured it was worth highlighting. If you manually move the bed,  it causes the backlight on the screen to illuminate. This seems like a potential problem to me, albeit very niche. Shouldnt there be some reverse polarity protection on the stepper drivers? to not induce a voltage on the power rails?
Thoughts?
Dieses Thema wurde geändert Vor 4 years von Sayum
Veröffentlicht : 19/04/2021 10:25 am
RE: Manually Moving Bed Issue
It's normal behavior, don't worry.
Veröffentlicht : 19/04/2021 10:36 am
Fayoh
(@fayoh)
Manually rotating any electric motor will cause it to act like a generator. So you backfeed the electronics from the motor instead of from the power supply.I
In practice this has not been found to cause any problems. There's some video on youtube (I mean, of course there is. How could it not be 😅) Where someone really tries to force the motor to induce some kind of fault in the electronics, but nothing happened.
Veröffentlicht : 19/04/2021 11:10 am
ToddG gefällt das
