Linear advance question
Hi!
I printed this mostly out of curiosity: https://www.prusaprinters.org/prints/53359-prusa-mini-linear-advance
The result was really inconclusive (attached a pic). For me, the lines look more or less identical. I try to compare it with the pics here: https://help.prusa3d.com/en/article/linear-advance_2252
I cannot spot major differences between the lines. Is is subtle, or is there something fishy going on 😀
br, Antti
Publié : 22/07/2021 9:21 am
Variations can be subtle
I see a difference with improvements as it gets higher. Actual results will vary with filament. You could try a more dramatic print to highlight the differences:
(Ignore the numbers on this print, those are the old LA1.0 values)
In your example, I'd go with 0.4.
Publié : 23/07/2021 3:03 pm
