lcd dispaly
alan
 alan
(@alan-2)
lcd dispaly
i have a problem with the dial on the lcd board it turns but dos not move
as i am a pesioner money is tight and the cost of new one is very expensive
it has been surggested that i have the encoder dial replaced but am have trouble finding one
dos anyone know the part number  i would need
thanks in advance
Respondido : 01/04/2021 9:08 pm
RE: lcd dispaly
Just to confirm that you are referring to a Prusa Mini panel, correct? That unit is new and I would think still under warranty. I'd try contacting Prusa support via online chat before ordering a replacement. Log into the online store and use the chat function.
I only see the board and case available directly from Prusa for about $54. It looks like you can order just the board for roughly $18 if you don't mind a clone from AliExpress. I haven't used this board myself, so can't speak to how well it functions.
Respondido : 01/04/2021 9:14 pm
alan
 alan
(@alan-2)
RE: lcd dispaly
hi
the printer was bought used from a friend
i have spoke with online adviser and he just directed me to the £74 total price one
i ask if he could provide the part number for dial  ssaid he would reach out to his colleages
to see if e could get the part number
if not will have to go via the china route (didnot want to do that but needs must)
thanks
Respondido : 01/04/2021 9:23 pm
Turro75
(@turro75)
RE: lcd dispaly
With a multimeter also check the flat cable.
If You feel confident on soldering the replacement part should be easier to find as it is a standard rotary encoder which is quite common in arduino projects, just look for "EC11 encoder".
Otherwise go for the replacement display. Please note that if You printed a display back cover, there are specific stl for clone.
Respondido : 01/04/2021 10:41 pm
alan
 alan
(@alan-2)
RE: lcd dispaly
hi
thanks  dont have back cover  hard to find smd version of ec11
Respondido : 01/04/2021 10:43 pm
Blindside_o0
(@blindside_o0)
RE: lcd dispaly
2 Years Later! I found a solution. I had a problem with my MK3S+ LCD display Rotary encoder. I would turn the dial one way and the system acted as if I moved both directions. I even contacted @Prusa3D and found out about it being an EC11 but there are multiple styles of EC11. I desoldered the encoder from the board and unbent the tabs on the bottom. There are no components to fall out so don't be too worried. I found out if I pulled up slightly on the contactors inside and regreased inside the component, everything now works fine. Also, I discovered the missing data, EC11 with 15mm plum handle.
Respondido : 15/03/2023 2:42 am
2 les gusta
trondkla
(@trondkla)
RE: lcd dispaly
thanks for posting! Looks like it's the same for the prusa mini 🙂
Respondido : 28/02/2024 4:38 pm
SushiSushiSushi
(@sushisushisushi)
Miembro
RE: lcd dispaly
Posted by: @blindside_o0
Could you tell me which one you bought that worked well? There are so many and I don't want to get a crappy one.
Respondido : 12/08/2024 2:25 am
