How To Install Firmware?
bill2009
(@bill2009)
I downloaded the english-czech firmware from here Release 5.1.2 Firmware for Original Prusa MINI, MK4, MK3.9 & XL · prusa3d/Prusa-Firmware-Buddy · GitHub
I put it on a fat32 usb stick and put it in the usb A port of my mini then turned it on.  it booted as usual and still shows the 4.3.4 firmware.
what ami i doing wrong?
Napsal : 28/07/2024 2:49 pm
Studio Sagan
(@studio-sagan)
RE: How To Install Firmware?
Posted by: @bill2009 what ami i doing wrong?
First thing I would check is the file permissions on the USB drive. I think it's unlikely to have read permissions turned off but it couldn't hurt to make it read/write for everyone. You could also try downloading/unzipping again and using a different USB drive with no other files on it.
Napsal : 28/07/2024 4:31 pm
vhubbard
(@vhubbard)
The rules on my MK4
USB2 stick, FAT32
Only 1 .bbf firmware file on the top folder of the USB drive.  If there are 2 or more .bbf files, it will not work.
Make sure it is the version for your printer.   There are MINI, MK3.5, MK3.9-MK4 and XL versions.
Once the USB stick is inserted, use the RESET button to get system to re-read the USB drive and initiate the update.   It should then ask to install firmware.
Napsal : 28/07/2024 5:05 pm
bill2009
(@bill2009)
Posted by: @vhubbard
The rules on my MK4
USB2 stick, FAT32
Thanks.  I've verified i have a single bbf file on a freshly formatted 4GB USB stick, the file is named MINI..., it's recognized by the printer when i plug it in but ignored when i push reset.
Napsal : 28/07/2024 5:53 pm
vhubbard
(@vhubbard)
Try step 8 here.  Othewise it suggests trying a different USB2 drive.  Good Luck
Napsal : 28/07/2024 11:28 pm
bill2009
(@bill2009)
Thanks for the replies.  after googling around a bit i tried updating to 4.4 (i'm at 4.3.4).  that worked and updated the bootloader. i don't know if i'll have to do eaach individual release - i'l try 5.1 next.  instructions could be better.
Napsal : 31/07/2024 2:14 pm
