Hiccup every 3 rotations on x-as and y-as
Hans van der Pol
(@hans-van-der-pol)
My Movie-360p30
I assembled my Prusa mini and at first it gave me layer-shifting properly caused by the strange hiccups.
I tried everything to fix it and as last I upgraded the software to the last version. 6.2.2 and that causes the calibrations to fail
To rule everything out I got the stepper motor out and it's still there. It's on the x-as and y-as, tried also a new stepper motor but it doesn't fix the problem
Is there someone that can give me a clue?
Posted : 10/04/2025 1:59 pm
_KaszpiR_
(@_kaszpir_)
RE: Hiccup every 3 rotations on x-as and y-as
Its hardly visible without something attached to the shaft.
Also, are there any noticeable obstructions if trying to spin it manually ( when motors are disabled in the menu)?
Posted : 11/04/2025 7:40 am
Hans van der Pol
(@hans-van-der-pol)
No, there are no noticeable obstructions.
I put the printer together again and now yo can hear the sound it makes.
My Movie 2-360p30 My Movie 1-360p30
When I rotate the stepper motor before calibration the sound you are hearing is on an other location on the slide
I also found out that the 3 rotations hiccups are on all stepper motors including y-as and extruder.
Posted : 11/04/2025 8:30 am
_KaszpiR_
(@_kaszpir_)
Factory reset?
Posted : 11/04/2025 6:52 pm
Hans van der Pol
(@hans-van-der-pol)
Yes, First I tried a factory reset and that changed nothing after that I upgraded the firmware to the latest version and that also changed nothing.
I have no clue what to do next, because all stepper motors have that strange behaviour the next logical step will be the controller board but for some reason I can't imagine that it is a hardware failure because between the hiccups (mis steps) he is working very smootly.
Posted : 11/04/2025 7:25 pm
_KaszpiR_
(@_kaszpir_)
I suspect (wild guess) issue with:
- generic electromagnetic interferences - from other electronics etc, or cables being too close to each other
- damaged electronics in the board (servo controllers)
- unstable power supply
Either way it may be good idea to talk to Prus Chat for help.
Posted : 12/04/2025 7:37 am
Hans van der Pol
(@hans-van-der-pol)
Thanks for all the help.
I ruled out this interference the rest I can't
I hope the Prus chat can help me out 🙂
Posted : 17/04/2025 1:42 pm
Hans van der Pol
(@hans-van-der-pol)
I found out that the knocking sound of the stepper motor was in sync with the screen flashing.
I just disconnected the LCD screen and use the web-link to print my stuff, Now the printer really works fine, no knocking sound and a great printing result, and it is printing much faster.
It's only painful while (un)loading the filament. I need to connect the lcd screen for that.
I tried the Prusa chat to help me out, but they always force me to connect the screen and then try to help me with solving the knocking sound as if it's a mechanical problem.
I'm at a point that I just want to buy a new lcd screen because I'm not able to convince Prusa that it is no mechanical problem. But I'm not really 100% sure that the LCD screen is the causing the problem.
What do you all think?
Posted : 02/05/2025 3:13 pm
_KaszpiR_
(@_kaszpir_)
I would start with the inspection of the lcd cable, maybe there is some damage to it ( though sometimes bit visible), and then moved to another lcd display if the cable is ok.
Posted : 02/05/2025 11:28 pm
Hans van der Pol
(@hans-van-der-pol)
Thanks,
There was no damage visible on the flat-cable, but when I flatten it up the flashing was suddenly gone.
When I was assembling the mini the instructions showed that you need to round up the flat cable in push it a bit in the aluminum profile on the bottom side.
At that point we found that a bad idea, but we just followed the instructions, I think at that point I damaged the cable.
 I will replace it with a new one. Thanks for all the help.
Posted : 03/05/2025 6:58 pm
_KaszpiR_
(@_kaszpir_)
Well, you cable may be damaged... or not. Maybe the cable was too close to aluminium profile or adjacent cables were too close to each other, thus getting interference.
Try to run it with flat cable and just use a duct tape to attach it to the aluminium profile, or print special brackets for it and see how it goes over time.
If the issues comes back maybe then buy a new cable?
Posted : 04/05/2025 6:55 am
