RE: Having trouble with print quality (under-extrusion) after printing with relatively no problem for a year or so.
then do a cold pull https://help.prusa3d.com/article/cold-pull-mini_126399
and print this please print with skirt and dont stop it unless it slips off bed thanks
Alright, I don't think there is but I will keep an eye on it while it does the calibration.
Here is a first layer calibration, will try other stuff here in a second.
now ive got picture thanks
soryy image is a bit fuzzy if you still have it can you zoom in on the square please
and if no of that works try tighten the extruder gear screw a little bit not as much as you originally had it but a bit tighter then what it is now
hows it going
About to work on it
ok
hows it going
Did a few cold pulls, about to print test. I also tightened the extruder bolt a smidge.
ok fingers crossed for this print
Print settings for that.
ok so quite a bit of stringeness
yes indeed
you can see the lines how old is the fillament
try do a first layer cal again and take close up photo of the square
