RE: Having trouble with print quality (under-extrusion) after printing with relatively no problem for a year or so.
i think maybe the fillament could be damp
Filament is brand new, has only been out of package for like a few days, conditions are generally decent where I have it too, so I wouldn't expect it to have any significant moisture issues.
If this first layer cal doesn't work I will try switching to some prusament that I have
yeah might be best once fillament changed over do first layer cal again please
Not great but that is what it did not changing anything, currently set to 0.930. Going to check with prusament here in a minute.
try lowering the z height
Alright I will lower it a bit, currently attempting with some Prusa PLA.
ok
yes that is a verry good first layer
hows it going
yes the tubes look fine it is ok for it to slip on bed will do on all printers and the brim has printed prfectly so i would say that your printer is running perfectly
what do you think ?
Yeah that's about what I had before as far as print quality goes in general. I would agree that it's running pretty good.
Must have just been bad/damp filament. Very weird considering I just got it. Any thoughts on that?
it can happen what make is it
put it in an oven for 5 min 80 degress thats what i do
Hatchbox PLA
hatch box unusal for that to be damp have you ever used hatch box before
try do first layer cal with hatch box fillament again just to see
